Underfuelling to Overfuelling
(In Topic #78016)
What are they ways i could (either do myself or not) to get it bang on, or even rich?
You screw it into a spark plug hole. allows you to see if the engine is burning the fuel correctly. You then adjust the mixture until its ok.
They work well. Halfords do them for ?23
i thought id try another dub forum in my local SW area and one clever person said "take it to a garage and get it done, the end"
even tho i just had that done lol.
well if it goes down to it ill try that thanks.
where did they check the fuelling from ? exhaust tip ?
make sure your exhaust has no leaks in the joints as this will make it look lean but it probably won't be as the extra oxygen in the gases will take the lambda reading up
cheers Stu
www.msportcam.co.uk
sorry no idea where they took reading from. but i guess it doesnt matter too much anyway.
as i dont even know how or where to adjust it even if i wanted to.
if you look at the metering head from the front of the car, between where the braided pipes are and the rubber moulding for the inlet pipe there is a small tube that sticks up from the airbox if you get a long i think 3 or 4mm allen key and turn it say an 1/8th of a turn clock wise this will add some more fuel i don't know how much extra fuel but it will add some just don't turn it too much and make a note of how far you've gone.
hope the explanation helps
Stuart
www.msportcam.co.uk
