Transmission Oil Level
(In Topic #207430)
Simple question
This is the stuff I've used, you will be luckly if you can get 2L in the gearbox after draining it out so 2 bottles is plenty.
Useful tool to undo the drain and filler plug.
http://www.ebay.co.uk/itm/DRAPER-38323-3-8-SQ-DRIVE-DRAIN-PLUG-KEY-17MM-HEX-AUDI-BMW-ROVER-VW-GEARBOX-/391539944325?hash=item5b29996b85:g:tNkAAMXQ1ZhTjJnS
Make sure you remove the filler before you undo the drain plug incase you can't get the filler off and left with no oil in the gearbox.
