Torque wrench for engine rebuild
(In Topic #232980)
Recommendations
Just wondering if anyone has any recommendations on a decent mid priced (£50) torque wrench that's supplied calibrated ?
I have one of these:
https://www.checkline.com/blog/wp-content/uploads/2014/12/gallery1.jpg
So I usually set the wrench, then test it on the tool and adjust it if needed to the proper torgue, if it is under by a little like 86 instead of 87 in/lbs I usually leave it alone.
Used a wall mounted device back in the 70's on aircraft, that had a needle that you used the torque wrench on it and the needle stayed at the breaking level the wrench was clicking at. Or on a dial wrench you could see where the needle on the wall was in comparison to your needle on the wrench…
The problem with calibrating them is that are you sure they really did calibration? Our torque wall gauge was calibrated every month.
I too have two torque wrenches - a 1/2" drive one for the big stuff and a smaller, 3/8" that goes down to (I think….) 8Nm or thereabouts. Obviously a 1/2" and 1/4" might do it too, depends on the ranges. 3/8" is handy because a lot of sockets are that size anyway these days. I think mine is a Halford professional one, bought it ages ago.
