Top dead centre
(In Topic #145565)
Top dead centre
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
as above use the flywheel mark its the most accurate way, its the small punch mark NOT the big diamond.
there is also a notch on the crank pulley which lines up to an arrow on the timing belt cover, but this can be out. the outer part of the pulley can slip round if the rubber damper is a bit worn, i worked on a mk3 8v which was over 90degrees out on the crank pulley!
