Timing and ignition
(In Topic #122505)
Timing and ignition
I'm trying to time my engine (1.8 8v) it has a kent cam fitted but the revs seem to be pretty high and it back fires even on tick over.
I've lined the groove on the flywheel to the point on the bell housing screw threads using my timing light on no.1 ht lead. Is this the correct way of timing the engine???
Also, it feels and sounds like there is a miss fire/ not firing on all 4. The exhaust gases splutter out and when i excellerate it doesnt seem to be very responsive and it's rather slow. It sounds like a v6 or something. I've fitted another new coil pack, new dizzy cap and rotor and new plugs. any ideas? the firing order is set to 1342?
(Got TDC on cyl 1, checked where the rotor arm was on the dizzy and went clock wise on each ht point on the dizzy cap with ht lead 1,3,4 and 2.???)
Cheers for your time.
Crank pulley has a groove on the top and is lined with the other pulleys dot, the cam (vernier pulley) is alined with the rocker cover bolt, flywheel marker is lined with the point on the bell housing thread and the dizzy rotor arm is on ign cy 1. I'm at a loss now. i put the timing light on the fly and the marker is lined with the point on the bell housing thread.
I'm checked the vacume hose and that is on the tb.
Cheers guys,
Cam aligned to head
Crank to TDC and aligned to oil pulley
Throttle body tickover screw is all the way in, and when the engine is running the mark on the flywheel is set to the arrow on the bell housing thread.
Does anyone know where i'm going wrong because i'm lost now, It ticks over far too high especially with the Kent cam.
There are no air leaks and the idle air controle valve is fine.
Do you think it could be the fueling as it runs like a dog when you drive it?
What size allen key do i need toadjust the mixture?
Thanks again
Member 125 - 2005
The pic i have up of the dizzy has no dust cover. If you click on the picture then click on it again it should zoom in. If you wouldnt mind having a quick look and describing to me where the line is i'll go and do it now. thanks again
Member 125 - 2005
Timing and ignition
I've set the cam (note there is a retard and advance marker on the pulley, could this help with the idle?)
Then i undid the belt, tool the dizzy out and re-lined the pulleys with Cyl 1 at TDC
I repositioned the rotor arm on the dizzy and refitted it.
I stuck the cam belt back on and re-jiggled the firing order 1,3,4,2 (clock wise) cyl 1 being the top left lead on the dizzy cap.
I then stuck the timing light on the flywheel when the engine was running and adjusted it till the mark (painted in white) was in line with the mark on the bell housing
It does sound like it idles better but the revs seem to be pretty high and i believe there is a missfire? see what you think of the video…
http://yfrog.us/j3img0716z
http://yfrog.us/j9img0715z
Shared with ImageShack http://stream.imageshack.us/redir.php?sl=img687/2360/img0716.mp4
Timing and ignition
