Temp Gauge Increasing Whilst Travelling at Speed :-0
(In Topic #122106)
Whilst travelling at speed I notice my temp gauge shoots up to 3/4 of the gauge - Not travellled long enough to see what happens after…..!!!
Is this normal??
Gaz
MK1 1990 16v GOLF GTI CABBIE
You'll need to do a few checks to find the fault.
At normal running it sits under half way - when travelling at speed increases to 3/4 - Is this normal?
Gazza
GazzaBangor said
Hello Warren, Long time no speak! How is the 16v conversion coming on???
Hi Gazza, 16v is done, Mot'd and taxed :cheer: :cheer: , have a couple of things to tweek, which I'll sort on Friday, then it's off to Midland Festival of Transport on Sunday :wink:
Next time it gets upto 3/4 pull over and quickly see if your cooling fan is running, Dont take too long having a look as the fan will kick in pretty quickly when you stop, but the ram air effect of driving down the road at this time of year should keep her below the temperature that the cooling fan kicks in, f the fan is running then you have a problem which may or may not be addressed in my previous post.
I will try it next time I travel in excess of 100mph!
ive just recently bought a VR6 Carrado. the plan is to put the engine and gearbox into my mk1 cabrio. Ive only had it for a few days but have noticed the temp is running MUCH higher that my 1.8 cabrio.
WATER TEMP is 230 F (110 C) (this is high right)
OIL TEMP is the same, but when i CAIN it it shoots up to about 260-270 F (130 C) (think OK)
