strange misfire on my gti
(In Topic #120544)
checked for a spark and that was fine, replaced the plugs, leads, rotor arm and dissy cap to be sure and the spark is a bit better now but the problem was still there. checked at the injectors that fuel was getting through and they were also fine, put them back in with new seals and still there is a misfire.
im now thinking it must be electrical, maybe ecu but i was wondering if there is anythink else that i could test first as i hate electrics :roll:
the engine is using a bit of oil through the stem seals (i think, the tappets keep getting loud then going quiet again) but i wouldn't have thought this would make a difference, it may be somethink else though?
has anyone else experienced something like this or have any thoughts/ideas on a solution. help would be very much apreceated.
also if all else fails how hard would it be to swap the engine for the 1.8 8v gti engine?
thanks
missfire
also got a new ignition module earlier as i have heard similar symptoms from these failing.
if none of these things work, i have acess to a bosch gas analyser / dyagnostics computer at uni so ill get it on that and see whats what.
thanks for the help.
also the plugs wern't looking too clever. no. 1 looks as it should, sort of grey and dry, however the other three are all black, kind of sooty and a bit damp. im guessing the fuel must not be burning properly in these three cylinders but i dont know why.
any ideas people?
Following your compression test you could try putting a drop of oil down the plug hole of no.2 cylinder and testing again. The oil down the bore can create a temporary seal around the piston until it gets spread around. If the pressure comes up a bit then dips away it might indicate worn rings/bore. If the pressure doesn't come up it might point to the valves or head gasket. Doesn't tie in with the no.1 missfire though.
did another compression test yesterday with the throtle fully open, cyl 1 showed 130psi, cly 2 130 psi, cyl 3 125 psi and cyl 4 135 psi?? as you can see these bear no relation to the first set of results that i got so i still dont know what to make of it. hopefuly i'll be gas testing it later so that may show something (fingers crossed).
