strange cutting out?
(In Topic #119165)
me an a mate towed it home but due to so much cranking my starter motor finaly gave up. thats now been replaced with a new one and i made a new battry + connecting lead. car will now turn over and starts beutifuly but will run for 3-4 minute then cut out of its own accord. then it will run for one minute and cut out then not at all for anuva 10 minutes!
i can hear the fuel pump priming and runnin (and yes ive got lots of petrol lol), i have spark during crank when it wont start 2. i have done continuity cheks through the whole ignition system (coil, ig amplifier, hall sender on dizzy etc) and found no resistance anywhere.engines had new plugs 3 months ago, coil dizzy cap and rotor arm 2 months ago, has been timed and tuned perfectly and i have new performance ht leads bein delivered tomoro. also fuel pump relay 4 months ago. tried startin with spare known good ig switch too but to no preveil.
does anybody have any other cheks that i can do that they have done to their golfs or have had this problem before, im guessing its kinda electrics side orientated an thats not my strong point! any help will be appreciated.
cheers, boyle
mk1 golf - resto
mk3 polo breadie - daily banger
Could simply be krap in the fuel.
Is it a mechanical fuel pump?
mk1 golf - resto
Regards Volkswarren
mk1 golf - resto
Regards Volkswarren
mk1 golf - resto
boyle_sbd said
kool man, thanks for the help, prob will rig up a stand alone tank an pump i got at work and runn it off that first to test before shelling out ona new pump, does snd like a gd bet tho. safe
I would hazard a guess that its the ribbon cable in the dizzy, mine had same symptoms and it turned out that the cable to the hall sender was just parting under vacuum which was causing instant cut out of the engine, would restart fine most the time, if you are able to swap the dizzy then try it as there is no easy way to find the fault without dismantling the dizzy and flexing the wire with a meter on it. Hope that helps!
got a second hand fuse box from crazy quiffs the otherday, opend it up and there was no corrosion but gave it a good clean anyway an replaced the burnt out connectors in the multiplugs and fitted the new fuse box. after i gave my battery a good charge the car turned over nicely but still no start. fuel pump was not priming which was a bit gash so i bypassed it with a fused jumper wire and it evntually started . i let it run unitll hot and tehn turned it off. after leavin it for 5 mins it started again which was good. i then started playing with every thing to find the indicators made the indicator relay go mental and not make the indicators work and when ii press the horn the indicator relay goes mental and the engines revs drop.DOH!
looks like ive got more electrical issues. im gessin in the steering wheel area hahah.more cheks tomoro i gess. im hoping that the fuel pump relay is shot thats why it wont work unless bypassed!
mk1 golf - resto
