Starter motor wont spin with key
(In Topic #115941)
When i turn the key starter wont spin,if i put power to red/black terminal on the starter,she fires up fine. i have continuity from ignition switch end of red/black and starter motor end,but no voltage when cranking.i have changed the ignition switch,but still nothing.does this red/black run straight to the starter or does it go through a relay.what is the small black wire for at the starter.this is sending me nuts…any ideas..
stu
Cars,Cars Bloody Cars!!!
Re: Starter motor wont spin with key
i must be missing something,the black wire going to the other pin on the starter is a double wire,where/what does this do,where does it come from,the wires to the coil also lokk a bit iffy,but like i say once i put power to the red/black terminal car starts and runs fine!!
thanks mate
i'll let you know the outcome
stu
Sorted
thanks again
stu
