Start up Issues
(In Topic #83600)
Start up Issues
Hardly any history and It was cheap so can't really complain.
First morning wouldn't start.
Started after 5 minutes of trying with the jump leads
Rang my local garage. booked in for a service.
take it in the morning, get a call in the afternoon for the work that needs doing.
rear brakes seized, cam belt, fog light, horn, track rod need thingy worn and he would look into the problems starting.
6 days and ?600.00 later I pick it up, runs miles better.
The next morning, not starting
The guy said he had cleaned fuel system, injectors and warm up thingy.
Anyway summary
Takes at least 5mins of turning the engine over before it starts. I nearly always have to jump it from another car.
once it starts if i touch the gas for the first minute it cuts out.
try starting again takes about 2 minutes
Please please help
I'm like a kid with a new toy, except it doesn't work
Sounds like the 5th injector isn't firing. Its easy enough to test - you unbolt the 2 allen keys, disable the coil and lay it across the engine, when you try to start it should squirt for 4-10 secs or so.
If it doesn't work, its most likely its electrical connection that's dirty/corroded/misplaced. If not, it could be the thermo time switch or its wring at fault.
Thanks Paul,
I'll test it tomorrow
