Single speed cooling fan... Suppliers?
(In Topic #139525)
Any ideas who might still have these in stock?
I'm not aware of any new ones being available… Happy to be proven wrong though!
Yes its a 2 pin one i require but my present one works perfect just has a little bit of play on it, and some small chips out of the blades.
I just wanted to replace it with a new one………Call it OCD….lol.
I will just need to find out how to wire it.
Obviously 2 of the orginal wires will just link to the standard wires……………What about the extra new one?
you coudl wire up an emergency dash switch to the fast speed though
So i just get a 2 speed fan, 2 temp sensor and just splice the 2 wires into my original loom 8)
if you have the right spade terminals you coudl crimp them onto the end of the mk1 wires and pop the mk2 plug on
Just one last thing……if i get a 2 speed fan, Which one should i get as there are numerious wattage fans i could get?
http://www.vwheritage.com/vw_act_search.searchResults_lang_EN_country_GB.htm?sType=quick&maxDisplayRows=25&searchText=fan&veh1Type=g1&btnSearch=
fan
i settled for a 3 pin 2 speed fan and just used the 2 pin sensor. I snipped the fan plug off and put two spade connectors on fitting them to the two outer pins on the fan. it works fine.
