Setting up timing, - pics
(In Topic #151550)
after new head gasket
I have never replaced a head gasket before but can turn a spanner and am prepared to have ago!!
Got head off and didn't align any of the timing marks.
Head got skimmed and I have put it all back together again. Problem is that I can't get it to run right.
Followed all the set up guide on the forum. I can sart it and it will stand and run but its very lumpy. Took it down the road and its juddering alot.
When I turn the idle screw on the back of the throttle body it doesn't seem to be doing owt although when it's right in the engine stalls and the same when I screw it out too far. The rubber gasket seems fine. Doesn't seem to be any air leaks either.
Going back to basics, have I set the timing up correct do you think?
I started by lining up the 'v' mark against the arrow on the gear box. I have since seen on other threads not to do this and to go by the punched dot?? I can't find a punched dot!! This was done with no1 valve at the top.
I have then set up the cam belt with the markings as thus:
All help and advise needed, I am sick of taking the kids to school on the bus!!
the punch mark is further round to the right in that picture hidden inside the casing. you need to tun the bottom end clockwise a few degrees (looking at crank end) then the punch mark will appear.
this is what it looks like (pic shows gti spec diamond @ 6 degrees)
you can use the haynes measurement to put it back, use the EV spec:
Removed the dizzy and reset that, started her up and bingo, was much better.
Adjusted the timing with the gun and it idles at about 1000rpm.
Only problem now is that it is slightly lumpy. I am as sure as I can be that the timing is now correct. Do you normally have to adjust the idle screw on the back of the throttle body?
I am possibly getting ahead of myself now but…….
When I turn the idle screw on the back of the throttle body, should it change the engine running characteristics straight away? as mine doesn't!
In moving the idle screw, do you then have to adjust the co screw on the metering head? Have read in the other threads that that needs to be done on a machine to set correct but was hoping to get this sorted without spending anymore money!
best bet though is make sure everything is tickity boo first though, rerplace vac lines change the idle screw o'ring, check inlet boots for splits etc then fiddle the co
whatisit said
Started this before xmas and really need to get it going again now!!
Hi there, sorry to hi-jack your thread but I think Im surffering the same problem.
I was checking my timing again today as my car is also running very rough after a rebuild, including head gasket.
I thought that all my timing was correctly set up, but after checking today I noticed that my cam timing mark was lined up to the top of the rocker cover, not the top of the cylinder head.
In picture 5 and 6 above, it looks like yours is also lined up to the top of the rocker cover? Im assuming all your other marks were lined up when you took the photos?
I thought the top of the rocker cover was correct, but when I checked on the auto data program at a mates workshop the picture clearly shows to line up mark with top of the cylinder head.
So, if the the camshaft as lined up with the top of the rocker cover and not the top of the cylinder head wouldnt that make the cam timing out and subsequently make the engine run rough as its out of time??
Last edit: by rubjonny
Before I took it all apart thinking it was wrong
I have found another pulley, which I though was an intermediate pulley, it has the OT mark you mentioned, so is this an Intermediate pulley or a cam pulley??
Im using a 3A bottom end, and I did use the DX intermediate pulley but it doesnt line up with the crank pulley, but when I use the pulley in the picture as the intermediate pulley it lines up perfectly with the dot! So what do you recommend I use??
the one above is the later version but the OT mark isnt any good unless you fit late style plastic timing belt cover set.
ignore the markings on the intermediate shaft though, just make sure the rotor arm is roughly pointing at the notch in the dizzy housing. it only needs to be close enough so the engine fires, after that you fine tune dizzy position with a timing light
You might be able to help me? Heres what I did today….
Ruled out compression, All reading were well with in tolerance for every cylinder, with the biggest difference between cylinders being 30 psi, which is not ideal but still well within the limit of 45psi (Haynes Guidance Figures)
I re-timed the engine, as the cam timing was a tooth out. So know I know everything is okay on the timing side of things.
I moved onto the metering head. After I had adjusted the timing I tried to start it and it took ages to fire as usual, then fired for a bit but cut of straight away, it then fired first time but just idled at like 100rpm for about 10 seconds and backfired.
I then checked the air sensor flap and it was jammed shut
After closer inspection I could see the plunger was jammed right into the fuel distributor. So I removed it carefully, cleaned it all with petrol, wet rubbed the pin smooth and put it all back together, put it back on the car and again it wouldnt fire, wouldnt even catch a bit. When I checked the flap again it was moving but it was very tough to move, is this because there is now pressure from the fuel pushing on the plunger? Therefore making the flap stiffer?
I removed it all again and noticed that the little bearing inside the metering head flap, where the plunger sits on, was seized and not rolling like it should. Could this of made a difference?
The fuel distributor plunger is now moving nice and freely when off the car, but could the unit still be broken??
Does it matter that the little bearing/wheel thing doesnt turn?
I have access to about 3 or 4 mk2 golf 16v metering heads and fuel distributors, would these work? I've read a couple of threads which say it can be done, and a few which say it can't be done, but no difinitive answer!
Otherwise I'm just going to try and source a good second hand one from a mk1 gti. Are the 1600 and 1800 metering heads the same on the mk1's?
Could this be used?
Going to give mine an outing this afternoon, fingers crossed I get there and back!
Many thanks for all your input Rubjonny.
the corrado 1.8 16v unit is the same as the mk2 16v, but the 2.0 16v is totally different and no good for your application.
the main problem with metering heads in general is there is no easy 'reset' position for the mixture screw, so once you change them it can take a lot of faffing around before you get the screw in a position that allows the car to start!
Took it out for a 40 mile round trip last night.
1 - Seems to pull okay and does go well go but there is a constant slight splutter for want of a better expression.
2 - When I turn the idle screw it doesn't seem to do owt
and
3 - there is a constant high pitch screech which sounds like it is coming from the camshaft sprocket area, tone alters with revs.
Any advice?????????????
Has your idle screw rubber o-ring perished? Maybe worth a check.
The sound you describe sounds like the alternator belt slipping? But this obviously wouldnt be from the area you describe. Are you sure its coming from the Cam pulley area?
