Scraping noise from bottom of engine
(In Topic #158114)
Just wondered if anyone can hazard a guess at what I may be experiencing at the mo.
I was out in the mk1 16v today and when I pulled up after a short run I could hear quite a loud grinding/scraping noise coming from the crank pulley/water pump area. At first I thought it was the alt belt rubbing on the lower cam belt cover but I don't think it is.
What would bottom end bearing sound like if it were gone? Or the water pump if it was in the way out?
Any other ideas?
Thanks in advance.
Bob.
Mk1 golf gti campaign… 16v ish…
MK3 gti 16v
is the mk1 rusty? depends what you mean by rust….
MK3 gti 16v
MK3 gti 16v
MK3 gti 16v
I,m going to run the car without the alternator for a few seconds to see if the noise disapears. (once my fuel pump relay turns up, see my post in the electrical section
I'll report back once I find out what happens. I hope it is the alternator and not anything internal…..
Thanks Bob.
MK3 gti 16v
MK3 gti 16v
So I took the top cam belt cover off and …….noise gone. Glad I found it and that i wasnt anything internal. I put it back on now and gave it a bit of a giggle and the noise comes and goes.
I think i'll look at getting a new cover as this one looks a bit distorted.
Anyway thanks for the help.
Bob.
MK3 gti 16v
MK3 gti 16v
