Rattly Engine
(In Topic #241858)
10w 40 semi synthetic and a good quality oil filter like MANN.
I get mine from Euro car parts and been using there Triple QX oil for many years.
Don't forget to change the copper 14mm sump plug washer as well.
Will change the oil at the weekend and see if that improves it thanks.
Bizarely pil pressure gauge just sits at 5 bar so I'm going to need to sus out what is going on with that too..
Next job is to sort the vdo oil pressure guage that is permanently pegged at 5 bar..
Haves1979 said
Oil changed for some 10/40 magnatec and first impressions are it sounds better. Certainly sounded better from cold.
Reverse the wires on the sender, as that is a sign that the wires are reversed.
If your sender has the same profile here is how the sender should be wired.
The typical Oil pressure sender for a car equipped with a oil pressure gauge is a can type.
My 93 Cabriolet 1.8
Don't use the "cheap" cans that you buy off the internet, use a good quality one.
There are 2 wires on the can, The yellow is for the low pressure at idle warning going to the dash, it would be the wrong lead for the Oil pressure gauge on the center cluster or lower console. (flickering oil light at idle).
The Oil Pressure part is operated by the blue/yellow striped wire.
The car had a recon engine about 1k ago so it could be they just fitted the wrong part.
mark1gls said
Oil temperature sender is on top of the oil filter.
And is black.
I need to buy the right oil pressure sender, but the black one on the old filter looks to be in place.
It's now showing the oil warning light on cold again, accompanied by a slight top end rattle. This still clears quite quickly, although it's starting to take longer to clear.
I'm assuming it's not a sensor etc given the rattle, so do you think a new oil pump is a good idea? Engine has less than 1k on it although that's over 5 years.
