RANDOM idle!!
(In Topic #125960)
RANDOM idle!!
I have a rather frustrating idle issue. When its cold it can either start on the button or not……when it does start it it can idle at 950 or 1400rpm. Once starting to warm it usually idles about 1400-1300 and varies around this figure once warm. If i stop and let the engine cool and restart it will idle at 950. then once warm and i push the accelerator it will go back to 1440-1300!
Its getting on my t*ts and im lost with it. I squeeze the tube at the back of the inlet manifold and it makes no difference when warm and is functioning perfectly on the warm up. The fith injector is not running as i have removed this whilst its warm and its not spraying.
Does anyone have any ideas? Thinking it could be the warm up reg but how do you check this? Air leak from some where but i have check it once.
Help or ideas much appreciated
Dan
It also has an issue when accelerating in which some times it seems as if it's being starved?
Anyone got any ideas what's going on?
next check the injector sopray patterns and delivery volume, pop all 4 out and sit in 4 containers of equal size. put a bridge wire across the 2 large terminals on pump rleay socket, then lift metering head flap by hand all the way up, then release back to idle. check spray patterns are nice cone shape with a fine mist, and measure volume sprayed by all 4.
wipe the tips and remove the bridge wire then watch for drips, shouldnt be any for at least 5 minutes.
if an injector has a problem swap it with another, if problem moves the injector is faulty, if not the line or metering head is faulty. if 1 injector is faulty swap all 4 for new ones, can sometimes get brass merc ones for cheap off ebay.
Once thats all checked out only thing lef tis to have the fuel pressures checked using proper k-jet fuel pressure gauge setup.
8V
16V
Sportline
Campaign
16V
Sportline
Campaign
Thanks for your help
8V
16V
Sportline
Campaign
16V
Sportline
Campaign
