power probs
(In Topic #91085)
power probs
hi everyone i have just got myself a cabby and only had it 3 days and now it seems to be losing power and back firing badly its a 1.6 gli can anyone help?
air flow problems maybe??
flux capacitor
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v122/paulchalt/myadvitar.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
I'd get the timing and mixture checked out first
going to get the timing and mixture checked out will keep you posted.
could it be the fuel pump? as it dont half make a racket,thinking of replacing it and the filter
noisy fuel pump is quite common
FLUX CAPACITOR SEEMS TO BE FINE NO SMOKE OR ANYTHING ....LOL
GDOGG said
FLUX CAPACITOR SEEMS TO BE FINE NO SMOKE OR ANYTHING ….LOL
Check the wattage - if I remember correctly you need 1.21 gigawatts.
1983 Lhasa Green GTI
Remember to keep it simple. Check the cap/rotor/plugs. Could be a timing issue.
Was a flux capasitor an option on these early cars? Mine dosn't have that…or A/C.
Start simple,do the normal service items as they probably need doing anyway.HT leads,Timing,check the distributor isnt loose.
Check wires to coil are all in good condition with good contacts
Clean any earth points that look suspect,main engine/gearbox and rear right cam cover bolt wire
If your flux capacitor is playing up..on a Mk1 its usually a bad earth :wink:
also, you need to check your wufflevalves, these were a common problem on the gli models
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
don't forget to check your testes
as said, do the simple stuff first. many a wallet has been battered by not following that route.
