Possible Fuel problem.
(In Topic #144857)
since i purchased the car there has been a very noticible flat spot when ever i tried to accelerate,and the fuel sender is permenatly making a whining noise.
i decided to clean out the throttle body as i had read that this could be causing the flat spot.
reassambled and fired her up again.It was running very rough and then stopped ticking over altogether.
the fuel sender is still permenantly on,sparks are fine on all plugs.
should i check the fuel lines,filter,motor or injectors first.or do you think it could be something else?
thanks
jamie
Fuel lines/pump. If you search on here you'll find info about!
jamie
