Overheating fixed (?)
(In Topic #72453)
the gauge does sit very close to the the top end of the scale though when at idle and about 3/4 when driving along.
all those with a rad with a built in expension tank where does your gauge sit?
Timing can effect the temp of water and oil.
Weirdly though the oil temp jumps 10 degrees higher though when the lights are switched on :roll: . Dodgy electrical connection there somewhere I think.
Fan seems to cut in when it should and keeps things cool though so not unduly worried.
Oil temp has been as high as 110 in heavy stop start traffic…. My old Mk2 16 valver used to reach 125 sometimes though 8O, so not unduly worried.
Chris
The oil is high 90's to low 100's too, except in heavey traffic.
One problem (I think) is that the water gets to this temperature VERY quick, with 4-5 mins stood still my fan will be cutting in!!! Any ideas? I'm sure it should take about 15-20mins before the fan cuts in when the car is stood still, especially in this weather!
Billy
Talking to others I think that's the way it is. They just run hot.
I swapped temp senders and that changed where the gauge sits. I don't think it's an exact science.
Getting the timing done properly made the most difference.
I was reading about an article about oil coolers in Golf+ and it said the oil cooler in a mk1 is thermostatically controlled, is that right?
Peter.
1980 1600 GTI, daily driver.
Heard that these gauges aren't that accurate or reliable and that you can only really use them as a guide to whether the temnp is going up/down or staying stable?
1983 1100 C
1983 1100 C
as i said the fan kicks in and out and it doesn't over heat so will leave it.
thanks for your responses guys
