Oil pump
(In Topic #186037)
its possible the hydro pump replaced solid lifter but i cant see any evidence of this in ETKA?
Think the non hydro pump was shorter originally as some info on the net suggests it had shorter
"3: Oil delivery: Oil volume is important! If you want to race, you'll need a high volume oil pump! If your bearings are not receiving a constant flow of oil, they will bottom out and decrease the life of your love. All hydraulic engines from 85-on have higher volume pumps. Why spend aload of money on a pronounced "high-volume-performance" pump when all you need to do to your solid lifter engine is install a pump from a hydraulic engine? "
