Oil Pressure
(In Topic #72562)
Oil Pressure
Apparently there are no holes in the block and it has a new oil pump so the problem has been diagnosed as being a faulty oil pressure release valve. The seller doesn't know where this is located, and whilst I could take it to a garage to sort or source a Haynes manual I wondered whether anyone could shed some light.
The key to correct diagnosis is seeing exactly where the oil is coming from. Have a look and let us know…
If it is leaking from between the block and the (cast alloy) filter housing, you need a new seal here (easy enough, except the access is poor with the radiator still in place)
If it is leaking from between the filter itself, and the housing, this is usually because the filter was fitted too loosely, or without wetting the seal with engine oil (seal bunches up when tightened whilst dry, and allows oil through) - in this case, remove the filter and re-fit it correctly, and tightly enough (you might need another filter if the seal is badly folded/torn).
If it is leaking from somewhere else, let us know, and someone will be able to tell you about what to do…
The oil is not leaking, instead it's squirting out between the filter and the housing, seconds after starting up.
Apparently the same problem occurred 200 miles ago, but a new oil pump solved the problem until now. Two filters and have been tried and properly sealed, but the pressure is too great still and forcing oil out.
Unless the oil pump is faulty (it's a new VW part) or incorrectly fitted I guess my only option is to strip the oil sump/pump and cooler and check for problems.
1983 White cabriolet GTi
i'm just supprisesd that the car has covered 160k without this being looked at before. Might be worth looking for cracks in the housing too, I've never heard of any problems with them cracking but I guess it could happen.
Finally had time to work on Golf and by process of elimination concluded that needed to change oil pump just in case the one bought previously wasn't duff….and it was!
Car now running sweetly!
Snowie
