oil light flashing and a buzzing noise.
(In Topic #122527)
so i put another half a litre in and it still kept flashing and then it started buzzing
now when the oil light flashes it also buzzes…..
first things first im sure my dipstick is not reading corrcetley… ie dont think its the right one and it has red plastic on the end of
the sleve at the top looks like its been broken..(sure the original dipsticks didnt have plastic at the top)?????
i just thought 1.5 litres of oil should of stopped the light flashing let alone this buzzing noise (im sure ive read someone else having this buzzing noise before)…
i know i need to get the correct dip stick set up to ensure what level the oil is currently at…. or…..
is this just a gremlin someone has had before….
oh and the car is a standard campaign
thanks for any input on this issue i have………. spencer
I'm no expert with this but I think you'll find it's an oil pressure warning rather than oil level. However, don't panic just yet !. It seems quite a common problem and if you do a search (in the toolbox section on the left <—) or look in the archive section, you'll find quite a lot about it…I know this from experience.
On mine the buzzer and light were going off all the time, even with the engine off. Ended up changing the whole instrument cluster and not had a peep since. Usual symptoms seem to be that the buzzer/light start flashing over 2000 revs which suggests to look first at the senders.
Anyway, like i say have a search and i'm sure you'll sort it. Sorry cant be of more help, good luck mate.
Paul
yes the buzzing and flashing starts when the revs proberly hit about 2k…
getting a new pressure switch turning up tomorrow so hopefully thats the problem….
then i need to drain out some of the extra oil i put in
thanks again paul…… spence
on the mk1 in any of it's guises
I'll try and source a link.
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
much help
i have new clocks to go in as well to get my mfa working… now i have a real reason to fit them
spencer
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
