No spark at the plugs........ideas welcome
(In Topic #80850)
The car is a 1983 GTi.
Last week I was taking a run up the A41 towards Whitchurch and decided to stop for half an hour, when I came to start her she wouldn't go and after numerous attempt winding her over she fired and ran perfectly. After another 20 mins I stopped for half an hour and the same starting problem occurred, then drove again for 20 mins then stopped and came to start her after an hour and same problem again, worried at the battery draining I got a friend to put his jump leads on and she started straight away. The next morning I thoughtI might have a problem, but she started within 3 seconds, I ran her to work, turned her off and went to start her and she wouldn't start. Before all this started she would start instantly, I can hear the pump priming before starting, the tank and pump etc are all new, I have just bought an ignition control unit, coil and fitted them but I am getting no spark at all, I am waiting delivery of a brand new dizzie, but wondered if anyone with years of golf wisdom knows of any other silly things it might be.
but i havent got years of golfy wisdom behind me :dontknow:
rebuild in progress....
Guest user
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
www.vwcaddy.com
I'll let you know if it works.
Thanks for your ideas, any other ideas are welcome as I'm sure someone else will get this problem and search the forum in the near future.(and also I might be wrong about the Hall Sender, and wont know till the dizzie turns up
d
cheapest checking alternative.
Birmingham
When I turn the ignition on I get the initial two sec burst from the pump, but when I'm winding over as well as no spark produced, I cant feel the pump whirring, I know the pump relay and coil are connected electrically but wondering if the power at the LT side of the coil could be drawn away by a dodgy pump relay…..the relay is only 3/4months old from GSF.
More ideas still welcome
HTH
I traced the fault to a wire by the battery that leeds to the coil which wasn't secured properly and thus streching the wire, which looks good on the outside and breaking on the inside.
woth a try
check all the sensor wires are still attached where they belong, after i found the sensor wire and reattached it, it started and ran perfectly again.
something sooooo simple causing soooo many problems
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
