Need advice on running issues on KR engine.
(In Topic #125030)
its a G plate with engine conversion to a KR engine.
orginal fault with the car was corroded fuel filler pipe which rusted the inside of the tank, knackered the fuel distributer, choked the injectors etc.
I fitted new tank, filler piper, second hand fuel distributor and injectors. It now starts with a bit of help and idles fine when warm, the problem i have now is no power to cold start valve when cold and no power to idle control valve, when i power both of them the car starts and idles fine from cold.
the two seem to be conneted but not to sure.
I have checked all the fuses they are ok.
if anyone can shed some light on these fault i would be very greatful
many thanks Robin
as for 5th inj, it gets power from the starter motor pin 50a, via the spade with 2 black wires to it, so check that.
