Most economical carb setup
(In Topic #135140)
I have been toying with using carbs with my 16v 2.0 Golf. I will be running the car as a daily and wondered if there was a more eco setup available on carbs?
Ideally I want to do away with the 42 or 50mm inlet manifold and keep everything neat and tidy.
If there is not viable option with the carb, does anybody know or an alternative inlet manifold for the engine? I have seen images of non turbo vehicles running audi inlets.
Beware just swapping the inlet manifold for something else. They're designed to be a certain length for a particular reason - to optimise flow due to Helmholz resonance. By all means if you understand this and can successfully redesign the inlet tract to make it more efficient, do so, but can you show your calculations proving its better?
A friend at work is quite clued up with air flow and we have a flow bench here that we could use. Although he is keen to test a few things, I think I will stay with the simple route. Although I want a tidy engine bay and 'the look', if there isn't an off the shelf solution then I am not going to bother.
It is possible to get a set of carbs and run them with the K-Jet system?
I have braced myself so that I don't fall off my seat.
OEM_Dub said
Go on then … how much.
If you have to ask, you can't afford it.
