MK1 Gti mixture issue
(In Topic #99034)
Does anyone know what the mixture screw should be set to to get it running?
And yes i do feel like a twat
welcome to mk1 heaven :wink:
Mainly the one in the metering head i fear is the one i have messed up
if so dry and clean then try and start :wink:
if you screw it down it will lean it up i belive been along time since i played with the k-jet system :wink:
bens_cab said
not really youd need a c0 tester to get it to where it should be however ive always managed to get it done by smelling the fumes and getting high works tho![]()
Clockwise = richer.
If you're lean, you can squirt cold start into the air box to make it run
if you're rich, holding the throttle part open during starting will help
Thanks for yuor help
btw is bens_cab the forum guru as he seems to answer most questions asked
is your carb jon
wouldnt say your a mug at all - asked 2 questions in two days and youve been a big help with one, and hopefully a big help with this one as well
im crap with carbs
your best bet is to get down an mot station and bribe them with beer tokens to set the c0 up on there machine :wink:
so no ideas where the screws would be to adjust the mixture?
may be worth while posting a thread in big carb engine section
cheers mate
