Mk1 golf cabi major help needed asap
(In Topic #74380)
Anyone else had this?
Its a 1990 gti cabi,all standard.New plugs,fuel lift pump etc
Also are all these cars bad when its been raining? took me hours to get it going today!
Excessively weak mixture, covered during warm-up by the richer mixture required from cold.
Low system pressure* in fuel metering head - the spring in the primary pressure regulator* gets out of adjustment, it needs shimming by a Bosch service agent. The symptoms are similar to what you are experiencing, as the low pressure is covered up during warm-up by the higher control pressure* provided by the warm-up regulator.
*look at Domain parking page for more info on these concepts.
Of course it could also be an electrical item breaking down as the temperature under the bonnet goes up - coil, HT spark plug leads, etc, especially as you also mention that you had more trouble than usual in the wet weather.
ben
