mixture screw?
(In Topic #75979)
mixture screw?
i know i ask a lot of questions but…..
what's the right tool to adjust mixture screw?
ta
mark
you push it down a small way when you will feel some resistance, just push it down a tad more and turn it.
if the flap gets pushed down too far it will cut out.
i cant remember which way makes it makes it more or less lean, but im sure you will find out when the engine cuts out or starts to race! but i think its Clockwise for richer, anticlockwise for leaner
hope this helps
Jon
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
mark
1983 1100 C
1983 1100 C
Just curious
Mike.
1983 White cabriolet GTi
However - if you've got a racing exhaust etc etc - the setting may not be so appropriate. It would probably be too lean, as you would have less back pressure from the exhaust, so you'd want to richen the mixture.
Your best (safest?) bet is probably to gradully richen the mixture and go for a drive after each (very small) adjustment, with a warm engine naturally. Check the engine response - if it's not picking up very well - i.e. if blipping the throttle isn't producing any response - then you're probably running lean.
Your local garage should be able to do you a gas check for not much money….
If you're determined to DIY these guys;
Garage Equipment Sales | Supplying Vehicle Lifts, MOT Testing, Tyre Shop machines
Do an emissions testing rig for ?2220 upwards…….
Oh - that's a bit steep isn't it 8O
Ali
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
As for the gas analyser, I know gunsons produce one that will just give you the co level for about ?60, don't know how accurate it would be though!!
Mike.
