Misfire
(In Topic #159135)
My 8v GTI has devolped a misfire under load. On start up its fine, then as it gets hotter the misfire starts. With my foot on the throttle only slighty it runs perfect, and when going down will it will rev no problem. But if I then put my foot down on anything else = misfire & no power.
Please help!
More info might help us with you problem...
Chris
Checked all the leads for dirt all clean and good.
is there a relay that kicks in when you throttle it under load?
Engines I am not good at lol.
Any other ideas?
At one point on the way home I was happily cruising alone doing 60'ish fine with no problems, but as soon as I press the throttle further it starts again.
I've recorded a video of it, I'll upload it in a minute
It's getting me annoyed now :0(
The only isse I had of late was the idle screw unwinding it's self so revs went up high.
Wound it back in again and no issues.
There is an O ring that goes on the screw could it be allowing more air than need be in when accelerating hard.
The air being forced past the idle screw?
Just a thought.
It's located just behind where throttle cable goes on the clip. Maybe worth checking yours. Been trying to look for the answer but it appears to be different solutions, IE leads dizzy rotor coil etc. I am sure jelly put new leads on for me when he did the short service for me, only thing I haven't had new was the coil.
What's your petrol gauge on? I am on under a quarter so gonna fill her up and see if that makes a difference. But not noticed this before?
Can't beat a German car
I Don't know when the last cam belt was changed, so it's on my to do list, along with gear linkage kit.
It was the bloody dizzy cap! And it's a genuine VW part less then 6 months old!!
I compared it to my old one that I kept and noticed the coil electrode in the centre was pitted.
Here's what the old correct on looks like:
Here's what the one I took off looked like:
What would cause this to happen to a brand new cap?
It drives perfect now, 1 lesson learnt here is NEVER throw away parts, they WILL come in handy some day!
I might take it back and demand a new one!
