Misfire when hot & cold :(
Hello all,
Wondering if you can help, recently got a C reg GTI cab and it doesnt run too great.
It misses on idle, and throughout the range. Does it when hot and when cold.
I've check the plugs and leads, seem fine and look virtually new.
Was going to try the fuel filter next.
Can't find any split hoses, am wondering if it could be caused by the water temp sensor?
any help appreciated
You'll need to change cap rotor leads and plugs.
Mostt likely ht leads. Does not matter how new they look it usually them at fault! I had a new GSF set pack up on me with in a year!
ok, i'll give that a go and change the fuel filter, see how it goes
