Lumpy cold idle
(In Topic #72212)
Lumpy cold idle
On a cold morning the cars idle will wander between 700 and 800 rpm. The idle smoothes out and hangs at around 800 rpm after a minute or to of driving (or allowing the car to sit for a couple of minutes) and is at 1000 rpm after about 5 minutes. I assume this means there’s must be a problem with a cold start component, but thats about it. It always starts first time and never stalls. Any ideas what component may be at fault?
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
Not sure on new prices but they are not cheap (I'm thinking ?50+ although not sure). Scrappy probably the best way as they are on many bosch models. Anyone know of direct swap models?
1983 1100 C
1983 1100 C
Quick way to check the aux air reg.
Start engine from cold.
Squeeze rubber pipe that comes out of the aux air reg. Revs should drop.
Wait till engine warm, squeeze tube again. Revs should be unnaffected.
If there is deviation from above it's not working in which case it's the warm up regulator which you can't check without fuel pressure gauges.
There's loads of old posts on the old register about this stuff.
Peter.
1980 1600 GTI, daily driver.
The first part (the one I got) was on brakes, have the other parts been any better?
The next two have more Golf parts listed in them, as you'd expect a lot of parts interchangabilty between VW & Audi. However, the first was a supplement, but the subsequent ones are printed insuide the magazine which is a bit useless for reference.
1983 1100 C
1983 1100 C
