Like so many wits end requests...
(In Topic #96761)
Ok where do I start.
Over the last year I have had a number of disasters and challenges and have, with a number of hours of therapy, bested most of them. Its the ones that stop you driving that trouble you the most - mine seem to be mostly that.
Can you help with this I hope the last problem? For a while…
I have a 91 sportline and it will insist on hesitating when you hit the accelerator, this is during driving and stationary.
It is also difficult to start. Once the engine moves above certain revs in the course of its acceleration the hesitation vanishes but returns when changing gear.
I have had the following done.
tune-up twice - according to the tuner all points check out (He keeps saying injectors but I think that is a guess).
New in-line fuel pump.
New in-tank pump.
All the basic replaced; plugs, leads etc.
New fuel filler.
Cleaned petrol tank.
I know there is a bunch of component parts, one of which may need replacing but I just wanted to see if anyone has experianced this problem before I buy yet more parts on a guess.
Thanks so much for any help.
Book.
Book.
91' Sportline
91' Sportline
id replace if not as a starting point
then maybe check the accumilator isnt weeping from the end :wink:
Could water in the petrol tank be an issue?
Will definitely look at these suggestion.
One new thing I have noticed.
When looking at the injectors and giving them a brief clean I noticed small water droplets coming out of them when I gave them a tap.
Could water in the petrol system cause this hesitation and poor performance?
Book
Book.
91' Sportline
91' Sportline
…either way it suggests leaking injectors….
Have you seen this:
Injector Test - pdf file
