Leaking fuel unions
(In Topic #231899)
Any ideas? They are all tight but can you get copper washers but with rubber seals? Its only ever so slight but a leak none the less.
https://www.ebay.co.uk/itm/Kit-5-COPPER-WASHER-KIT-FOR-BOSCH-K-JETRONIC-fuel-metering-head-distributor/223243647986?hash=item33fa5bbbf2:g:7b8AAOSw-4RadekW
You have to slighty clean them with Sandy type paper. to remove any burrs.
Holding them lightly with a pair of pliers, you heat them up with a Ciggie lighter or propane torch (butane ones work too), till they change from the shiny copper color dull. This reconditions the metal or re-annuls it.
I did this quite a lot on my Diesel, IIRC I only sourced new ones after about the 5th or 6th reconditioning. I also used a light coating of Fuel Rated RTV on both sides as I didn't want any leaks whatsoever.
I will try the lighter method to see if it helps. Surely there must be a fuel resistant rubber and copper washer so the possibility of leaks is much less.
Until then i guess new ones as mentioned aswell will probably be needed
but here is a link to dowty/bonded seals.
Gaskets & O-Rings | Rubber O Ring Seals | RS
arghhhhh phone…spellchecker
On the drive
Myvalver 89 GTi Grey mk2 16v
Regional Host NE
Re:
Eh lolKenneth Cartwright said
did put sizes of new copper ealing washers before, have a search…
Sent from my SM-G955F using Tapatalk
