IT'S FIXED!!!!!!!!!!!!!!!!!!!!!
(In Topic #73499)
I think I have solved the running problems i had with the car.
This evening I swapped the metering head over for a spare Corrado 16v one that my mate had lying around. WHEN i can get it started it seems to rev fine now, the miss has gone, though the fuse for the fuel pump is blowing after about 10 seconds meaning it is cutting out again.
I have the fuel pump on a switched circuit and I added a 15Amp fuse. Is this too low? is there a fuse in the standard set up? If so, what value?
Also, when i turn the ignition on and try to start the car, it wont go until I turn the pump off, then switch it back on again when it fires!?!?!
Any ideas? too rich a mixture perhaps? (corroado 16v is a 2.0L isn't it - probably set for a higher fuel delivery).
Any ideas appreciated!
Cheers,
AL.
My Build Thread
Probably is too rich - try starting with the Cold Start Injector disconnected.
crazyquiff said
unless it is has a higher system pressure requiring more power from the pump.
That is what I thought.
If the new metering head requires more flow, then the pump will be able to spin faster due to less flow resistance. This also means it would require more power from the battery, hence the current draw increases blowing the fuse… If I up the fuse to a 30Amp, would this still blow before the pump melts if the current got too much?
My Build Thread
I was just reading a link in another post that says the current draw on a fuel pump should be betweem 5 and 8 amps. If this is the case, then i certainly don't want to exceed 15Amps on the fuse as something is obviously not right!
My Build Thread
Bad news is that it is still missing on the old metering unit. I tried to take it apart to clean/look at it, though even with all of the bolts that hold the block together out, I could not seperate the two parts?!?! I didn't want to go at a precision unit with a hammer, so I whacked it all back together :dontknow:
My Build Thread
…And it is still missing!!!!!!!!!!
Really starting to waz me off now. I don't know where to go next.
Going to do a compression test to rule out head gasket, though I don't think this is the problem. Also going to get some jam jars and do the flow test that was in one of the other threads.
One question on this though, Do you do the test with the flap lifted fully?
I'm off to read through it again.
AL.
My Build Thread
Re: Found one problem - now got another...*UPDATE*
Cheers,
AL.
Depends which car it's off AL. Early Rado's were 1.8 16v's. Also the metering head has a warm up reg type attachement on the side on the 2ltr 16v which has a plug coming off it. So if you have a metering head with this type of attachment I reckon it will give you fuelling probs, as when they ain;t working it makes it run like its under fuelling on cold start. Bro has just had a problem with his 2ltr 16v and it was wheezy and missing when cold.
1983 1100 C
1983 1100 C
markwon said
Al - assume this is the same problem as on Phill's thread? When you say missing, do you mean failing to fire on all cylinders? Is this on idle, under load, all the time? Have you tried pulling HT leads one by one with engine running to identify the missing cylinder?
It is as if it is missing on one cylinder most of the time (Idle/ low revs/ high revs) but mostly under acceleration…
I pulled one lead with the engine runnig and it hurt so I didn't pull the others…. I shall try this tonight I think. At lease if I can narrow it down to one cylinder, I can swap the plug and lead to see if it is something as simple as that, though I would have to be pretty unlucky as both plugs and leads have been replaced to try and eliminate these items!
My Build Thread
It might be blocked injectors? That could explain why a higher pressure regulator solves the problem (pushing more fuel through so if the injectors are blocked, the nett amount of fuel is what it ought to be).
1983 1100 C
1983 1100 C
markwon said
Pull off the HTs with engine off and loosely refit on each spark plug (don't push fully on). You should then able to lift each one on and off its plug with engine running and without any pain.
Doh - That's a good Idea!
I would have thought I was intelligent enough to have though of that myself!
My Build Thread
1983 1100 C
1983 1100 C
Will also pull the leads one by one to see if I can identify a particular cylinder at fault.
Better do this bit first incase any spark finds stray fuel vapour eh!
My Build Thread
I would, could get messy otherwise
Engine seems to be missing at all rev ranges - on using colour tune the cylinders are firing at what seems an Ok mixture???
If I pull off leads in turn the revs drop off slightly but not dramatiaclly.
Timing is bang on as is cam timing - compressions are OK.
God knows how you test one though……..
