INJECTORS
(In Topic #145606)
INJECTORS
Sorry if this query has already been posted but here goes ..we are in need of a set of injectors so have been pricing them up about £50 a pop ..but i just need to check that the ones a gfs say are the correct ones ..theres a used set on ebay that have 2 seals the large at the top and small at the bottom ..on the gfs site the injector doesnt have a bottom seal ..so is this another part to be found ?? we havent the old ones to compare coz loads of bits where missing on the engine when we bought it
thanx in advance for any info
Dan
there are 2 shapes as well early ones with a single seal and late with double seals, both fit each other the extra seal is for the air shrouding. you can pull the end seal off if your car doesnt have air shrouding, and you can fit early type if the car does have air shrouding. makes next to no difference anyway. you can tell what type your car is by looking on the back of the head, if there is an extra vacuum port between cylinders 3 and 4 thats for the air shrouding. you can just cap it off to disable it no matter what type of injectors you fit.
the fuel lines are interchangeable also, early lines fit late car and vice versa so you can just change lines to suit whatever injectors you get
http://www.ebay.co.uk/itm/FERRARI-MERCEDES-BENZ-FUEL-INJECTOR-0437502047-/390444571631?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae84f5bef
we have just got the block back into the car and its rebuilding time !!
at last it seems like were getting somewhere ,would post pic of the progress but not sure how that works lol
anyway
thanx again
