Injector / hose differences?
(In Topic #203207)
I have a spare set of the coarse thread hoses and injectors without the shroud. Like this:
The spare set is in better condition so I'd like to fit these for what its worth (there isn't anything wrong with what I have - just, might as well)- Can I fit these too my engine or are they not compatible?
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
Member 125 - 2005
I removed the brown plastic insert as 1 was missing a little bit and the broke into little bits when I removed them but I had the head on the bench so I could pick up the pieces.
This is what I was left with.
What does the vacuum system on the back of the head actually do?
the air shrouded injector vacuum system is there to help atomise the fuel a bit better to aid mpg, supposedly the difference is noticeable on the 8v head but I've had both with and without on my 16v and I noticed no difference whatsoever
mark1gls said
I usually follow the old saying "If it ain't broke don't fix it"
I'm a fan of if it isn't broke, fix it till it is!
