ignition leads
(In Topic #115423)
ignition leads
Question. Is mine old type or new type tech, do i just replace the coil and dizzy cap to change lead set?? Hope you guys can help
Regards Richie
Cant mix & match, need to have all ign components the same. also the coils differ from electronic and contact breaker systems, so make sure thats the right one for your application also
What make of Dizzy cap do you recommend for the 1.8i dx engine ?
I have purchased a Motaquip cap and its rubbish . From experiance i know the carbon brush in the middle will simply break , far to much play
Are gsf or eurocarparts dizzy caps any good ?
baz
ECP tend to be a bit on the expensive side I found, I prefer AVS as their website is much better than GSF, plus not run by muppets!
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
thanks
