idle goes up and down after a cold start
(In Topic #77304)
A fitted a new auxilary air valve, so now I got rid off the cold 700rpm idle.
It has a new fuel pump,injectors, and fifth injector, and I cleaned out the metering head/warm up regulator filter and I have done the fuel delivery test on the injectors which was near perfect! What could could cause this problem?? During a constant speed, it still hesistates! Lowering the CO percentage to 0,7/0,8 has improved constant speed but not the idle which is a bit rough…..
Any help is much appreciated :wink:
yal
could be a cracked pipe casuing a slight air leak maybe? :dontknow:
It is a quite expensive part and was around 120 euro.
Good luck,
greets yal
Matthew
greets yal
Go through all the "When you buy an FI Car" tests and checks.
If you do not identify the issue there go through the electrics. Is the dizzy advancing properly? Coil breaking down? Bad wiring?
Check the condition of the air filter and for any obstructions to the air flow.
Will the engine run smoothly at 2000rpm when stationary? at 3000?
Can you adjust the mixture to get a sweet spot at idle?
Is the ignition timing correct and staying stable at idle?
rich
where can I find the "when you buy an F1 car" test and checks???
My dizzy advances, and mechanism is not stuck
I did al the electrical tests the haynes manual suggested, and the coil was ok.
When I tested the hall sensor I got 11 volts, haynes did not state a max. value only a min value of 4 volts.
My air filter is clean.
When I do the prowler test I get nearly the same quantity fuel at all 4 injectors. My new 5th injector does not leak.
The engine hestistates when driving at a constant speed, and also when at idle and when stationary at eg 2000 or 3000 rpm.
I can get a smooth spot when turning the mixture on idle!!!only then the engine hesistates more when its driving and on acceleration!
When I make the mixture leaner to around 0,7% idle gets a bit worse but the car drives better(accelerates a bit slower, duh with less fuel thats normal I think)
Its got new Beru ignition leads and bosch W7DTC triple electrode sparkplugs. Compression is perfect, only 125 000km and a new cilinderhead fitted.
Thanks for the help so far
greets yal
You can find that here http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=2948
Your problem might be a "sticking" metering head - might be worth trying another one to see if the problem goes away - they are not that expensive used and may help narrow the search - i.e. if problem remains then deffo not the metering head.
Rich
Life Member
Did all the tests that crazyquiff gave me, and I only havent touched the accumulator but I will. It does maintain pressure fine, as it always starts fine cold and warm and after standing for weeks!!
I polished the plunger in my lab, (as Im a dental technician) and all the scratches are gone now! Shines lile new! Plunger moves freely.
I would be tempted to buy a second hand one, but its almost impossible to find second hand parts here in Spain as the mk1 was hardly sold here!
Thats why I buy mostly new parts…..
I found out, that when I lower the CO% to around 0,5% with crank vent off the car does NOT hesistate when driving at a constant speed, but the idle is a bit rougher then!
I now raised the CO% to 0,8% and the cars also stutters when I accelerate, when I accelarate straight away after that again its fine!
grr, annoying
greets yal
Fuel pump is new, and I checked the plunger moves freely in the fuel distributor. I then took the car for a spin, and hesistates with CO% on 0,8 the same with 1,0&1,2%
What I find strange, is when I go downhill and dont touch the accelerator the car still hesitates!! When I press the clutch its gone, so its def. something with the engine….
:dontknow: yal
