i have a starting porblem, can anyone help
(In Topic #113692)
is it possible that the air flow meter is stopping the distribution valve from opening correctly, will adjustment resolve this ? can anyone help
apologies if i am using incorrect terminology, very basic understanding of the system i'm afraid ??????
If you can't, fuel pressure test.
weedeater said
there doesnt seem to be fuel in the injecter supply lines from the metering head if thet makes sense, should these not be pressurised with fuel ?
The injector test will determine this. Is there still no fuel flow out of the injectors, if the metering head's air flap is raised by hand?
