HT lead advice needed
(In Topic #124227)
Got an 83 tin top 1.8 GTI with a DX engine. I've been having a few problems recently and the latest has been the car running on 3 cylinders. I went through disconnecting one HT lead at a time while the engine was running and found one that made no difference so I'm going to replace them all. GSF didn't have any in stock so I popped to Halfords. On the car model guide it said that the DX engine was one type that they don't stock. When I spoke to the guy on the parts desk he asked my registration and on the computer it said about choosing between two different types. One for EV or JH engines and one for EX or PB engines. On the car model selection list it said that these were both cabriolet types. The guy said to go for the EX ones and they are also suitable foro MK2's including G60's.
Got them home and they are totally different lengths to the existing ones. That's not right is it?
Also I stupidly took off all the old ones and can't remember which one goes where. Does it matter? Is there a guide anywhere?
Anybody know where I can get some good ones over the counter? GSF said they could get me some in tomorrow.
You'll have to find where no. 1 is on your dizzy and then know that on a 8V the rotor arm goes clockwise and the firing order is 1-3-4-2.
I don't know why EV/JH and EX/PB are different since I don't actually have a car with these engines, but there might be a slight variation in the fittings on the coil, or length of the king lead eg on a Mk2.
Are the cylinders 1 - 3 - 4 - 2 from left to right looking at the engine from the front of the car?
Any idea where to get good ones? GSF ones good enough?
Technically you don't need the rotor to be at No.1 TDC, you just need to know where it is……but since dizzys get taken on and off on an old engine etc, its good practice to put it at TDC and physically look at the rotor arm, to be 100% sure. In theory there is a marking on the dizzy (on the inside somewhere) but in practice you could misfit things, say 90° out, and connect it up so it works.
Cero said
Yes & Yes, but you need the rotor on TDC on No1 to start with
sorry being a total retard here! Don't get this at all!
Also should all the leads be the same length? The ones I took off weren't! Don't particularly trust GSF at the moment!
You turn the engine to achieve TDC. Make sure its "valves closed" TDC too, since the crank turns twice for every 1 turn of the dizzy rotor arm. Basically its an standardised way to see where the engine is. You'll need to be able to find the timing marks on the crank pulley and/or flywheel, though. Once again its a case of, if you know what you're looking for its easy, if you've never seen it before its vague.
If the above is meaningless to you, there's 2 options:
1. Try the leads (in the correct firing order) in all 4 possible positions, since one of these will be right
2. Give it to a garage or mechanic to do the work (but you'll need to pay for this).
If It doesn't start in the morning I'm calling out a mobile mechanic!
Any ideas before I get somebody in who knows what they are doing?
1. You've fitted them wrongly. Could be wrong order, or that you've not pushed them fully in, etc etc.
2. They're broken (since they're new, I doubt this. But you could refit the old ones to double check).
3. They're the wrong ones. It might be this, and that the electrical connection isn't being made. Compare it with the old leads. It might be that you can bend the terminals or something, in some way, to make the electrical connection.
But then you have a spark so 2 and 3 seem unlikely???
I'm assuming you've not fiddled with anything else, or run out of fuel, or have an immobiliser and not turned it off, etc etc.
Had tdc correct and the leads correct on the cap. The engine was totally flooded so he showed me how to sort that by removing the fuel pump relay.
Anyway it's all sorted now!
Mate with a mini did this trick of removing 10 similar connectors in similar places and trying to remember where they all went and had me waste an afternoon trying to start is car. He got the ones at the dizzy end out by 1 position, 12 oclock was at 3 oclock and 3 was at 6 etc.
