High REvs
(In Topic #73020)
High REvs
The motor is still running at about 1500rpm when it idles even after it has warmed up.
Only thing that seems to bring the revs down is turning of and on again which causes a slight drop.
ANy ideas and possible fixes. What sort of revs should it running at when warm..
AAV, is working ok then any other ideas, is really starting to p me of. Especially now the revs have worked there way up to just shy of 2k.
Any other tests would be grateful..
Jonathan :dontknow:
Jonathan :dontknow:
Did you get this sorted? I'm having the same problem
Yeah the Idle stablisation valve thingy just behind the manifold on the right hand side as you look at the engine. That was the problem. One of the wires going into it had broke off. Once I reattached the problem went away.
Hope that sorts yours out mate.
Cheers,
That's more than likely it! I've been buggering around around there quite a bit recently, I'll have a look.
Member 125 - 2005
mine had just started to stick at 2k revs, followed tips on here but no joy, feeling around throttle-body touched air mixture screw thingy ? and found it was loose wound it back in a little and revs dropped back to normal. hope this is some use to somebody.
Still not looked at mine actually
