High Pressure created in fuel tank
(In Topic #74232)
I orignally posted the following question about tank pressure building up which is released when I undo the fuel cap. see post:-
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=1812&postdays=0&postorder=asc&start=10
If you read posts you can see GIT has a very similar prob.
I was happy to hear that it was normal but I always thought the vacuum created in the tank was too high. Anyway the other day I drove out to the country to give a mate a lift and when we stopped the car would not start again. It ran really well before we stopped. Anyway we tried to bump start it but the engine would not fire at all (fuel starvation). We waited for it to cool and checked what we could still nothing. I then thought about the pressure in the tank and opened the fuel cap and released the pressure, guess what it started first turn of the key.
Is it possible that the pressure was stopping the fuel pump from spinning. I have had a look at the breather pipe from the filler neck and it doesnot seem blocked, have not traced all of it but when I blow down it sounds like the one way flap in tank shuts and the air ruches back out of the pipe. Also checked regulator tucked above filler neck and seems to work. Cannot seem to find the other regulators as described in the haynes manaul. Anyway if anyone has any ideas then please do I am completely stumped.
Thanks in advance.
Cussco
pressure wil help push the fuel out whereas a depression/vacuum will stop the fuel bieng drawn out!!
See Fuel tank here:
http://www.ford-capri.…k/whiterose/Injection.htm
1983 1100 C
1983 1100 C
I had the same problem with my car in building excessive pressure so I
changed the breather valve with is fitted and hidden away under the inner wheel arch liner by the filler neck. It is a good chance the valve is stuck and not working. Approx ?30 from VW
Hope this helps
Mk1's never die….Just mature with age!!
www..eurotek-online.com …. watch this SPACE!!!
