Hesitating when warmed up. Why?
(In Topic #72306)
The point at which it hesitates gets lower and lower in the rev range until the point comes when you touch the accelerator and you do kangaroo style hops down the road while getting no drive from the engine. When I have to stop, turn off the engine and then it does better for a little while, but then it kicks in again.
Does this sound like a blockage/muck in the fuel line or injectors or is the MOT work coincidence? Any ideas what is causing this?
Your description sounds very much like a problem I had which turned out to be a failing coil. Try changing that first, if there are no better ideas here. Make sure you get the correct coil as the wrong one will get hot and cause the same symtoms!
My cars in the garage, right now, poor damp start, hesitation and kangarooing.
I've gone for the electrics first.
Coil, HT leads, sparks, dizzy cap, rotor arm, condensor, points (you won't have those!)
?113
This is a lot cheaper and easier than starting on fuel supply, and a lot more likely to be causing your problems.
And without the points easy to do yourself as long as you get the HT leads back on in the same order you put them on!
Peter.
1980 1600 GTI, daily driver.
Get the system pressure in the fuel metering head checked by a Bosch tuning agent (see Yellow Pages) - if the system pressure goes out of adjustment (too low) the car runs ok for a while as the Warm-up Regulator keeps it ok while the engine is cold but the pressure falls below what is acceptable as the temperature rises.
Unless something else is broken/knackered, it shouldn't cost too much to fix, as the pressure is adjusted by simply re-shimming a spring in the metering head, but this the changes required can only be measured with special Bosch tuning tools.
Life Member
Good luck!
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Life Member
It is actually like driving a different car!
It has new
And the timing was set.
They left the coil as it tested ok
The car now
Runs quieter
Runs smoother
runs cooler (I'm not kidding)
Smoother power take up (I thought the clutch was knackered)
No kangarooing (like when I decide I'm going to do 30 in 5th)
Starts without the engine even turning.
Why oh why did I leave this for so long!
Peter.
