help!!!
(In Topic #104313)
help!!!
But on accelaration there seens to be some kind of fuel starvation am about to check the Injectors are clear today :dontknow:
Anybody any ideas :dontknow:
Web Team
Are your fuel filters clean? Have you any debris in the fuel tank? Is your filler neck in good order?
at least it is running. a little spluttery thou? :dontknow:
shift like a bugger now!!!! acceleration is gud. occasional splutter! xxx :wink:
Have you checked the coil? I drove to an MOT one day but couldn't drive back - the coil just packed in, and gave symptoms much as you describe. The Bosch ones seem to work best. Some of the alternatives are really poor quality and don't last. If the ignition module isn't clamped to its heatsink properly it can overheat and give a misfire, but it would take quite a while to get hot.
I knew someone who overtightened the air tube jubie clips from the metering head to the inlet manifold which distorted the tube and let stray air into the engine. That will make it run rough too. Did you have to adjust the mixture to get it to idle ok?
Good luck - Big
