HELP !!!
(In Topic #79321)
HELP !!!
was just having a little engine tidy up,
and oil change..
there was a small leak around the rocker cover,
so i removed it and change the gasket…
the small oil leak is now massive..
loads of oil spewing out around the roacker cover ?
have i ..
over tightened ?
under tightened ?
its 1800carb engine on 1990 clipper
help please its a bit grim !!
and oil change..
have i ..
over tightened ?
under tightened ?
1981 mars red gti
2001 new beetle
1990 clipper
1981 1500 gls
2001 new beetle
1990 clipper
1981 1500 gls
If you have a torque wrench that does low torques you should tighten them to 10Nm. Thats just a tiny bit more than hand tight.
I had this after i changed the rocker cover gasket, when i changed the gasket a friend gave me this blue stuff to put on both sides of the gasket which is ment to insure a perfectly tight fit, however when tightening the gasket the blue stuff was still wet and the gasket slipped out of place, did you put the gasket on dry?
yes dry..
i done this job on my gti engine, no problem..
but today its like oil slick city..
help !!
help !!
1981 mars red gti
2001 new beetle
1990 clipper
1981 1500 gls
2001 new beetle
1990 clipper
1981 1500 gls
the gasket can't be on properly, you'll have to take it off and check it. This the the annoying bit. If you've used a non geniue gasket they're normally rubbish and will leak unless you use a sealer to make sure its on right and stays still. The geniune VAG ones have changed (a few years ago to be honest) for around a fiver you now get a rubber style mk3 type gasket which comes complete with new studs to use insted of your current one, these are 100% better than the cork rubbish that is normally on old Golfs
thanks alot chaps..ill try to get that sorted today !
1981 mars red gti
2001 new beetle
1990 clipper
1981 1500 gls
2001 new beetle
1990 clipper
1981 1500 gls
