help please misfire is driving me mad
(In Topic #82327)
could it be the fuel pump filters
i have spent the morning replacing plugs and leads checked the timing everything is new and working properly any ideas were to go next would be really aprecated :dontknow:
Does it miss/run badly when warm?
Have you set the idel screw?
Check all air hoses are secure and no splits. Check main inlet pipe is seated correctly.
Check auxuliary air valve operation.
Read the various knowledgebase posts
main inlet pipe has all new clips and is properly fitted nice and tight no splits in the rubber parts
R.I.P Dave Wilson
13/02/1982 - 12/11/2006.
To say I've lost my best friend……
======www.pureklas.co.uk======
before i started the engine this morning i checked in this order
cold start valve pressure check no leaks in one minute
then operation check did fire but only very short time maybe two seconds max bearly enoungh time for the volt metre to notice spray pattern is fine though
then thermo time switch sending current to cold start
air aux working working fine passed all checks
begining to think it is a ignition fault not injection will try changing the coil
will let you know if it sorts things out
ps replaced the air flow sensor adjustment clip in the right place
