Head gasket done?
(In Topic #140696)
Head gasket done?
one garage i have used before have done a test on the water to see if the oil has mixed with it, they used a solution which changes colour if you engine water has oil in it, might be worth trying that ?
1.8T CABBY
1.8T CABBY
trust me you'll know if the HG has really gone
what are the coolant symptoms you have been having
gsf
or eurocarparts in brum will do them.
Regards Volkswarren
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=113573
Regards Volkswarren
sounds like its a head core plug that has gone, which means the manifolds will have to come off to fix it as you'll have no room to swing a hammer
make sure you get 8 new studs and copper nuts from gsf, as the old nuts wont be in a state to reuse and at least some of your studs will be past their best
a mirror and long thin allen socket extension is what you need really otherwise its a bit of a nightmare
