GTi Engine swap or upgrade?
(In Topic #199494)
The dillema I face at the moment is what to do with my 178k DX engine. Compression is currently all over the place and it idles like nothing I've ever heard before! Under acceleration the compression seems to come good and it still pulls well, but I suspect it probably needs a at the very least a top end rebuild.
The obvious choice would be to strip and rebuild.
Choice 2 would be a straight replacement - G40 would be nice, but also considered either a PD150 swap or try to find a 180bhp TSi lump.
the other choice is a middle ground - rebuild but tidy up and make quicker.
If if I were to do the latter what do I need to be considering? My car has electronic fuel injection, dizzy etc so thinking mild cam and either TBs or carbs but what considerations do I need to make if I choose this route?
Engine guru input and advice would be massively appreciated before I start dismantling things
If if I were to tidy up the bay by installing TBs or carbs would I lose any of the clutter? I've seen many a tidy bay over the past few shows and I really need to think about getting mine tidy and reliable.
i suspect a simple top end rebuild would be down to how quickly the head can be removed and skimmed. I have had a head skimmed within the day before on a French engine. Couple of days should be achievable
Sticker Pig
9double9 said
The DX engine has K Jetronic fuel injection which is mechanical.
Simple enough to work with? As in if I were to change to TBs?
abfmk1 said
Your suggestions are all over the place, if you would be happy with current power levels just get existing engine rebuilt, its the easiest choice.
Just accidentally hit the report button…. Sorry!
The engine needs a rebuild anyway so that is my preferred choice, however I also want the bay to look less cluttered.
