full rebuild
(In Topic #156231)
I've had quotes from £2000 to £1100
its the standard 1.8 8 valve injection DX
How many miles has your car done? Is it burning oil? How old is the engine?
Untill its out of the car and you look inside its hard to tell what needs doing and replacing so thats is why the prices/quotes vary so much.
http://www.tsr-performance.com/webshop/parts-by-category/engines-and-engine-tuning-parts/tsr-circuit-series-engine-packages/donnington-1900cc-8-valve-package/
Bit of extra performance and your old engine in exchange (you might be able to get them to use your old block if you want to keep the numbers right).
I'm just waiting for a quote from Jabbasport and then I will make a decision.
Thanks for the help
Have you got any mates with an engine hoist who can lend a hand, it's not all that hard - just nuts and bolts
Engine out and back in for labour should be around £400….maybe a bit less but not much.
It's surprising how all the small bits add up…be carefull…the basic price maynot include sundries…oil, anti freeze, hose clips, breathers cleaned out or replaced, tappets re shimmed…shims…gaskets etc…make sure yr quote includes all that if your having it fitted.
www.jmrclubsport.com
