fuel relay failed again ?
(In Topic #151198)
Once I had finished swearing and cursing it and calmed down I noticed that the fuel pump want kicking in when I turned the ignition and also there was no "click" from the fuel pimp relay.
I am right, the fuel pump relay should click shouldn't it ?
That is also only 4 weeks old so I assume it must be a faulty product ?
or is there something that could cause my fuel pumps to keep breaking ???
Any help would be great, thanks
Why did I start this
But ! now when I select reverse the fuel pump relay goes nuts ( which was likley what happened before to make it fail)
Any idea's on what could be causing this ?
Thanks again
