Fuel hose
(In Topic #114905)
Fuel hose
I started my car for the first time in two years without a problem, the car was running sweet. Then i noticed a puddle of fuel on the floor. 8O
On closer inspection i found the leak (which is more of a squirt) on the upper hose that is connected to the fuel accumulator.
The lower hose looks in pretty bad condition as does the accumulator so i have decided to replace both hose's and the accumulator.
Anyway simple question is, what are the hose's called, and should i also be replacing the hose's after the two shorter ones. I do know that Crazyquiff and GSF sell the hose's but which ones do i need.
The fuel system is standard k-jet. 1.8 gti
Thanks.
Phil
Fuel Hose 171201218C
Fuel Hose 171201220D
he does a kit wi both 'ASL + FPA FPKIT ?67.00'
Been struggleing to get hold of him.
Phil
They didnt look to bad but i will only know when the others are off.
Cheers again
Phil
